Paint Codes from Build Sheet (Picture)
Old Jan 16, 2011 | 08:25 AM
Harmon's Avatar
I am trying to decipher my codes off my 1980 Olds Cutlass build sheet. It is not as easy as my 1972 was to find online. I am trying to find a site that can help me.
OR if I could get the color that would be awesome.
Thanks.
Old Jan 16, 2011 | 06:07 PM
Cameo White's Avatar
Smile
If no one here can help, you might try over at Oldspower also. They have more members with newer vehicles, I think.
Old Jan 17, 2011 | 05:49 PM
covertolds's Avatar
Have you tried www.autocolorlibrary.com?
Old Jan 18, 2011 | 03:43 PM
BlackGold's Avatar
LW = 11 means lower body color is code 11, which is typically a white.
UP = CC -- I don't know if this means the upper body is a vinyl top with code C, or if the CC means clear coat.
ST = 63 means the strip color is code 63. You'll have to look this one up somewhere.
W = 11 means the wheels are code 11, white again.
Your local autobody supply store should be able to help you with the codes. Or any GM dealer. Or maybe even the Duplicolor display of touch-up paints at your local auto parts store.
Boiler_81
Sep 22, 2020 02:05 AM
My442
Sep 9, 2012 04:23 PM
perro
Sep 8, 2012 07:45 PM
marzgtp1
Apr 18, 2008 11:48 PM
drtdobber
Mar 5, 2007 12:42 PM
