Oil Pan Gaskets
Old Dec 22, 2013 | 05:52 PM
Skiperoo's Avatar
Oil Pan Gaskets
How do you install new Oil Pan gaskets when the Engine is still in the car?
Thanks for a reply.
Old Dec 22, 2013 | 06:05 PM
  • Remove motor mount through-bolts
  • Jack up engine a few inches (crank just behind harmonic balancer is a good jacking point)
  • Insert lumber between motor mount area and frame to support engine
  • Remove oil pan screws
  • Remove oil pan
  • Remove oil pan gaskets (jackhammer and flamethrower recommended)
  • Clean surfaces
  • Install new gaskets, using RTV at junctions, and possibly smearing everywhere else, depending on preferences
  • Reinstall pan and tighten screws
  • Lower engine and reinstall mount bolts
  • Consider changing timing set and water pump while the pan is down, since it has to come down at least a bit to remove timing cover
Welcome to Classic Olds.
Old Dec 23, 2013 | 07:07 AM
Thanks for a reply.
While it's possible, once you go through all the steps called out in the CSM, you're only a few bellhousing and torque converter bolts away from simply pulling the engine. You'll be MUCH happier if you just do that. It's a whole lot easier changing the gasket with the engine upside down on a stand instead of trying to do this under the car while oil is dripping in your face.
Miles71
May 6, 2015 08:51 PM
twintracks
Jul 5, 2014 05:51 AM
bigblockolds
Dec 11, 2013 12:39 PM
rtpassini
Nov 20, 2010 05:58 AM
