Oil pan gasket
Old Oct 20, 2021 | 12:46 PM
wherlehy's Avatar
Oil pan gasket
Hello experts,
1970 Cutlas S, 350 Rocket.
I have a leaky oil pan (wife is sick of oil all over the garage floor), there is not much room between the cross member and the oil pan. Questions:
1. Can I replace the gasket by just letting the pan down as far is can (~1-2 inches)?
2. Can I take the pan off with that little clearance (repaint it)?
Thank you
Old Oct 20, 2021 | 01:40 PM
You need to pull the engine mount bolts and jack the engine as high as it will go an then turn the crank so that the pan will clear to remove. Frankly I'd rather pull the engine.
Old Oct 20, 2021 | 01:42 PM
wherlehy's Avatar
Shooooottttt.....
Who designed that Bullsugar!
Old Oct 20, 2021 | 02:26 PM
bccan's Avatar
Low Budget Oil Leak Management Device.
Why would you ever want to stop your continuous rustproofing treatment?!?
Old Oct 20, 2021 | 02:48 PM
RetroRanger's Avatar
72 Olds CS
yeah cardboard is cheap and effective
Old Oct 20, 2021 | 06:42 PM
Bfg's Avatar
Bfg
Tell your wife to stay out of your garage!
Old Oct 21, 2021 | 04:18 AM
joesw31's Avatar
It’s easily done on a 350 car. You will to lift the engine to pull the oil pan. Check your rear main seal as well.
57J2Olds
Aug 27, 2021 07:32 AM
VinMichael
Apr 12, 2017 07:25 AM
dnmfranco
Oct 31, 2013 12:40 PM
815Cutlass1972
May 13, 2010 11:43 AM
martine
Oct 17, 2002 11:52 AM
