Not Converting to Floor Shift Speedo!
![Arrow](https://classicoldsmobile.com/forums/images/icons/icon2.gif)
I'm in the middle of switching out the column shift, non-tilt, column in the Vista. Installing the obvious floor shift tilt column. My question is, how can I do this while also keeping the original speedo with gear selector? I still want it to function as before the swap. If I drill an oblong hole ih the steering column "bowl"and install the clip, link and indicator needle as was in the original column shift set-up, should it and will it still function? Has anyone done this before? I think the Buick A-Body floor shift column still operates using the selector in the speedo......?
This is a the ' 70 Vista.....
I suppose you are talking about the 65 Vista. Since the parts which support the needle movement in the column shift are not in the tilt floor shift I can't think your idea will be possible. Or I suppose anything can be done but this would not be something easily accomplished.
That should work as Joe says. and it is a great idea. That way you don't have to mark your Buick console and you will be able to see what gear your in on the speedo. This is how it is on my wife's '10 Impala. I like it!!
rgk1977442
December 8th, 2021 06:51 AM
Alocatelli
December 10th, 2012 07:49 AM
