From non air to Air 70 Cutlass Rallye 350
Old Jun 10, 2013 | 09:32 PM
sicky olds's Avatar
NôôB
Bought a complete AC setup for the Rallye 350 and i was wondering what parts need to be swapped out.
I know of the following:
Pulleys (from 2 to 3)
Water pump (?)
Dash Pad
controls
kick panels (from fresh air vents to flat ones)
Fan (from the 4 blade to the 7 blade)
add a fan shroud
What else would i be missing
Old Jun 11, 2013 | 03:40 AM
My442's Avatar
You will need to graft in a firewall from an A/C car.
Look at the factory assembly manual to see how different the firewalls are.
Old Jun 11, 2013 | 04:08 AM
You have to change the hole in your firewall from horizontal to vertical.
There are a variety of ways of doing this, anywhere from using aluminum siding scraps and roofing caulk to stitching in a piece of an A/C car's firewall, and everything in between.
I believe you will have to create the hole for the A/C wiring to pass through the firewall as well - if I recall there's a dimple there already.
Because the A/C air pass-through is different, I believe you also want the firewall insulation mat from an A/C car.
You'll also need the A/C heat valve that screws into the intake manifold.
This job is about a hundred times easier if you have the donor car next to your car in the driveway, or have at least pulled al the parts out of the donor car yourself.
Good luck!
Old Jun 11, 2013 | 04:24 AM
firefrost gold's Avatar
did you get a vintage air or other aftermarket set up or did you go with the gm parts ?
Old Jun 11, 2013 | 04:46 AM
tru-blue 442's Avatar
Old School Olds
Tom, if you are going with factory a/c stuff,
I can just about get you there with all the parts
I have, short of the graft for the firewall.
Let me know after you take stock of what you
need, and I will see what I can do. Did you get
a chance to check out the pics of the a/c dash
that I have for the 69? I have the controls as well.
Old Jun 11, 2013 | 06:52 AM
hookem horns's Avatar
You also need the drivers side alternator bracket in addition to the 3 belt pulley.
Old Jun 11, 2013 | 07:00 AM
sicky olds's Avatar
NôôB
Ok lets see if i can answer all of these questions here:
Eric: I do KINDA have a donor car for the job on this and thanks for all of the information
Shane: I bought an all GM setup from another member on here for the price of shipping. He swapped to Vintage Air and with my car being a numbers matching engine i am trying to keep it all stock.
Adam: I might be actually talking to you about this as I will be putting the AC back in the H/O when i get to that one. And no i have not seen the dash do you have a link or can you email it to me please
Dane: I did know that you need a driver side bracket and I think i can get the part i need from another motor that has AC out here.
Thanks again everyone for the help and do you think it is worth swapping it over to AC or should i just leave it non Air and use the fresh air vents?
Old Jun 11, 2013 | 07:55 AM
Originally Posted by sicky olds
... do you think it is worth swapping it over to AC or should i just leave it non Air and use the fresh air vents?
Fresh Air Vents = Convection Oven.
I would definitely say A/C is worth it, but there are guys on here who rip out their A/C and throw it away, so I would imagine they would disagree.
Old Jun 11, 2013 | 03:31 PM
Old School Olds
Tom, it's 95* in Marble today.
You live in San Antonio! Is is 97 or 8 today?
Not to mention the freaking humidity.
A 69 H/O with air? Ooh Hell yes, that's a
Central Texas keeper bud.
I might even have the cast iron #'s match
a/c brackets for the 69 455 too!
Old Jun 11, 2013 | 05:52 PM
sicky olds's Avatar
NôôB
That would be awesome, but honestly not terribly worried about keeping everything numbers matching in that car, But i do have a complete AC setup that i will be taking from another car. My question now is this, is there a different bracket from the 350 and the 455 ones?
Old Jun 11, 2013 | 06:27 PM
Old School Olds
Now THAT is a good question.
Someone will chime in. Joe P?
Aug 22, 2019 08:45 AM
69442murph
Feb 14, 2015 05:46 AM
e.cast728
Apr 7, 2014 04:14 AM
<1970-Rallye-350>
Dec 19, 2004 09:24 AM
