Neg battery lead termination location.
Old May 1, 2024 | 12:08 PM
T-Bone's Avatar
Hi. Just a bit of background. ‘67 442 wouldn’t turnover. Turns out it’s poor ground / connections issue. Cleaned all connections except main ground from battery. I don’t think the neg battery terminal wire is attached correctly. It appears whoever put it on just bared the wire strands & sandwiched it between the power steering bracket mount & the engine block. It worked great for Probly 30’yrs but all those years & engine vibration has & I think destroyed most of the stands & they are broken. I don’t wanna take off the power steering bracket & don’t think the connection is correct any way so I plan to connect a new battery lead w an eye termination fitting directly to another bolt on that bracket a bit easier get too. Anyone think that’s a problem?
Old May 1, 2024 | 01:49 PM
OLDSter Ralph's Avatar
Why not use a bolt on the end of the driver's side cylinder head ?
Old May 1, 2024 | 02:04 PM
As long as the connection on the engine is mechanically and electrically sound, it doesn’t really matter where you put the ground connection.
You could use one of the empty bolt holes on the front of the cylinder head. Does one of the cylinder head bolts have a stud on top? If so, use that. Lots of options.
Old May 2, 2024 | 05:15 AM
Oldsguy's Avatar
Past Administrator
Just make sure there is not a lot of grease/grime/paint on it before connecting it.
Old May 2, 2024 | 09:00 AM
Also make sure that the flat, braided strap at the back of the engine to the firewall is secure and free of corrosion, grime & paint.
James71Cutlass
May 27, 2023 04:59 PM
Reese Neis
Oct 26, 2020 07:00 AM
Texas442
Mar 28, 2013 07:13 PM
Seff
Sep 29, 2012 04:15 PM
silverriff
Mar 12, 2010 04:22 PM
