Need Help Identifying Engine parts
Have several engine parts and need help on figuring out what year and cubic engines that are part of. Figured some of them out already that are not on the list but still need help on a few of these. I've checked this forum and came up empty. Any info or help would be appreciated!
1) Crank with #58274. Its in a block 585786 which I found out that the block is a 64 Ultra High Compression block.
2) Gold block with stamping 561747 #3 CFD 340
3) Block with casting 561059 #2 CFD 117
4) Crank N 4813 99 2CFD
5) Head with a #3 next to the exhaust.
![](https://cimg2.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/645x81/195dc42f_20130215_thisthreadisuselesswithoutpics_jpeg_fff69c175122ace18a2e500323128472a79af46c.jpg)
I don't know about the numbers, but just measure the bore. I'll bet that red block will measure 4.125" (394) and the gold will measure out at 4"(371). Also look for a big 4 1/8 and 4 numerals on the back of the block by the extended bell housing
rocket hot rod
January 9th, 2007 06:21 PM
