Mtotor mount heat shield: 69 442
Old Oct 8, 2021 | 03:52 PM
grannys442's Avatar
Did 1969 442 have heat shield on both motor mounts ?
If originally only had one shield would it have been on driver or pass side?
Thanks,
Adrian
Old Oct 8, 2021 | 04:04 PM
Trophyblue442's Avatar
One on the drivers side only
Old Oct 11, 2021 | 11:12 AM
acavagnaro's Avatar
Confirming - one on driver's side only.
Old Nov 6, 2021 | 05:47 PM
jrhotes's Avatar
Replacing motor mounts
I'm trying to replace motor mounts in my 69 Cutlass convertible...can't seem to get engine high enough to clear. Will I need to remove exhaust pipes? Nervous about jacking up engine on harmonic balancer...any ideas?
Old Nov 6, 2021 | 08:46 PM
edzolz's Avatar
Since you have already hi-jacked the thread. I would not recommend jacking from the harmonic balancer. The best way is to make yourself a yoke that will clear the pan and lift the engine from the block/pan rail.
Old Nov 8, 2021 | 11:02 AM
acavagnaro's Avatar
As noted by edzolz, avoid putting any kind of bending load (jacking) on the nose of your crankshaft unless you're looking for an interesting way to kill it. If you're taking the motor mount bolts out, it only makes sense to drop the downpipes anyway. You do not have to remove the manifolds.
Old Nov 9, 2021 | 05:25 PM
BackInTheGame's Avatar
This is what I did. Worked like a champ!
Doug Carner
Jan 18, 2021 09:45 PM
Napoleon1991
Mar 31, 2014 06:46 AM
ent72olds
Mar 3, 2013 12:22 PM
mont1le
Feb 7, 2010 09:04 PM
Giddy
May 12, 2009 08:21 PM
