motor mounts
motor mounts
Hey guys, I removed my motor mounts so I can clean engine cradle. Do the motor mounts have any rubber on them or are they just a metal support. Mounts are from 71 Cutlass S with a 350. Thanks guys.
There's two different items here. The rubber mounts are bolted to the engine. Then there's something I'll call engine perches that are all metal and bolt to the frame cross member. Then the engine with rubber mounts is lowered onto these perches and a single bolt goes through one ear of the mount, through the perch, and back out the other ear of the mount. You need both.
John
John
joesw31
May 31st, 2015 04:17 PM
