Missing joint oldsmobile 88 1979
Hello everyone,
I come here because everything is working on this oldsmobile 88 from 1979 but there is a joint missing, it is the one between the inlet casing and the injection pump…and i cant find one please if anyone got the name/reference of the part im looking for or even better yet a link to one…
Any suggestions or help is appreciated, i live in France btw.
Thanks to you guys in advance !
Welcome. I'm not sure exactly what your question is, but that flange you have circled is for the thermostat and housing. The step in the casting is where the thermostat sits. The gasket between the manifold and thermostat housing goes above the thermostat.
Here's a schematic of the Oldsmobile diesel. Apparently, there's an adapter that goes between the injection pump and the intake manifold. If your's is missing the only place to find one would be a salvage yard engine.
You're going to have difficulty finding parts for an Oldsmobile diesel engine. Here's one source that I found with a quick Google search.
https://www.accuratediesel.com/6-2l-/-5-7l.html
Thanks for all the replies ! I did not expect such quick return ! you guys are amazing
So yes its the diesel engine, i’m not the owner (he doesnt speak english so i posted this for him) ill talk to him and tell him what you guys said.. so if i understand we doomed unless we buy a whole engine from the usa ?
I'm still unclear on exactly what question you are asking. The first photo you posted is an Olds diesel intake manifold. The area you circled is the location of the coolant thermostat and housing. The injector pump bolts into the hole just to the left of the circled area in your photo. What do you need?
