miss firing in the secondarys .....
Old Oct 4, 2010 | 05:32 PM
davepnola's Avatar
Help Please , I postponed putting the big block since we will be participating in cruising the coast this weekened.
So I tried a little tuning on the 350 rocket . first let me say this engine has 150 lbs compression accross the board hot , so i think this motor is stout ........
the problem is it will rev up strong through the secondarys in nuetral,
, but under a load when the secondarys hit , the car falls on its face and hesitates , missfires , back fires etc.... I am thinking ignition.... I have no way in setting the dwell on the points and I have been setting the timing really by vacume gauge , what about the resistance on the spark plug wires , what should the ohm out and how can I verify the advance vacume and mechanical is working properly......thanks Davepnola
Old Oct 4, 2010 | 05:45 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The secondary air door is probably set too loose and maybe to lean. Check your timing too.
Old Oct 5, 2010 | 02:58 PM
BlackGold's Avatar
When you rev it in neutral, the secondary air valve never even opens. Without a load, the engine will redline before they open much at all.
While the wrap spring on the secondary air valve might be too loose, it's more likely that your choke pull-off is shot. Also called a vacuum brake, it keeps the secondary air valve from opening too fast. Even if the diaphram isn't shot, it might have too large an orifice (replacements often do); the orifice in the end of its snout is what meters the air and controls the speed of movement.
The other possibility is that your secondaries are not flowing fuel at all (unlikely). If you ease into the secondaries VERY slowly and it never falls on its face, then the fuel is probably fine and it's the air valve that's the problem.
Svinet
Jun 15, 2010 11:09 AM
69sAndrew
Oct 24, 2009 10:57 AM
72rocket
Dec 30, 2008 08:31 AM
monahans10
Mar 9, 2008 07:58 PM
oldcutty
Sep 14, 2006 09:20 PM
