Milodon Pan
Milodon Pan
Hello, I need some advice on a rear pan gasket seal..!
What are you engine builders using for a method of sealing the rear main (not the seal between crank and cap) oil pan seal? I am using a Milodon 7q pan…should I be using a special gasket set or is there a sequence of installation and RTV I should be using?
This is my second attempt the motor in out of the car now..I’m putting in a cam and other stuff just dont want to do this again…..Please help any info would be great.
