Manual Brakes vs Power Assist
How driveable are cars with manual brakes (not power assist)? Got a 67 Cutlass Im putting together and it doesnt have assist. Can a car be stopped in an emergency situation with manual brakes? How much pedal effort is it?
Isn't that kinda like asking if a hydraulic clutch is easier to operate? The amount of leg strength a person has makes a big difference here. Some folks will have no problems but your 90 year old grandam may not have the same opinion.
My W-30s have factory manual brakes. I've never found that to be a problem in stopping, and I'm an aggressive driver. My 62 F-85 also has factory manual drum brakes, and again, not an issue. I'll add that when I drove on Power Tour last year, the leg along VA-58 was very hilly and winding, and those brakes got quite a workout. I will say that when I converted the 62 over to a dual circuit master cylinder, I went from the stock 1" bore to a 7/8" bore. That made a BIG difference as far as reducing pedal force needed. It's like power brakes now.
There's nothing magic about manual vs power. It's just where the leverage comes from - your foot, mechanical advantage, hydraulic advantage, or power assist. You can get exactly the same pedal force requirement with manual brakes as with power if you choose the correct pedal ratio and hydraulic ratio. Personally I prefer the extra feel you get from un-assisted brakes.
Hi,
I have several 65 GM A-bodies and a few have PB and a few don't, all have drums. Manual brakes take a bit more effort as mentioned, but are fine as long as you drive the car like it doesn't have modern disc and ABS, any older car was designed to be a safe daily driver, you just have to realize the way your car performs vs, a newer car.
One thing to note, I usually drive my manual brake car and first few times driving one with PB I about put myself through the windshield until I get the feel of it.
Regards,
Regards,
drjr56
November 29th, 2012 11:40 AM
