Kick Panel Removal - Please Help
Old Jun 26, 2011 | 11:44 AM
costpenn's Avatar
I must be missing something - how do you remove the driver's side kick panel on a Non A/C 72 442? The parking brake pedal assy seems to be in the way - do you have to remove it to pull the old one out?
Thanks,
Joe Munoz
Old Jun 26, 2011 | 04:43 PM
ziff396's Avatar
I do. It makes it alot easier to remove the screws, and only takes 5 minutes. There are 2 nuts under the hood kind of below the brake booster. Remove them and the one holding the assembly under the dash. 3/8? Just pull it back and a little out of the way and remove the cover on the kick panel. Now you can see the mounting screws and have easier access. Be carefull around the fuse block when moving the cable attached brake. Pull the ground on the battery. Good luck!
kansjfr
Nov 30, 2014 11:03 PM
wcourt3010
Sep 10, 2014 07:47 AM
ThePackRat
Jan 2, 2014 08:52 PM
msco123
Apr 3, 2010 10:51 AM
boese1978
Apr 20, 2008 03:30 PM
