Kick Panel Removal '71 Cutlass
Old Aug 26, 2014 | 07:14 AM
wcourt3010's Avatar
Kick panel removal on a '71 cutlass S hardtop. Can someone tell me how this is done? I see no screws to undo anywhere except one holding the vent cable in place.
It is not listed under "K" in my Fisher Body service manual, are they called something else in that book? As always, help is appreciated.
Old Aug 26, 2014 | 07:27 AM
NHolds's Avatar
On mine, I just pull off the sill plate, then pull it forward and out. It might have had a screw in it originally.. don't know. Mine aren't connected to anything anymore
Old Aug 26, 2014 | 07:55 AM
Seff's Avatar
Held in place by the chrome door bottom trim kick panel thingy, the A-pillar cover over it, and the two/three screws behind the vent grate, which pops out with a slight amount of force.
Old Aug 26, 2014 | 08:06 AM
oldspackrat's Avatar
Like Seff said, you must first remove the grill/grate. It has 4 or 5 tabs that hold it in, use a small flat screwdriver around the edge of it & you'll find the tabs. Once that is removed there are about 6 5/16" screws that hold it in. Once you get those out, there will probably be some thick whitish sticky adhesive that holds it to the body. You'll need to gently pull back & forth & in & out but it will come out. Just be careful not to break the slim vertical piece running up towards the roof. There also will be one screw holding one of the vent cables onto the cowl & the other cable just turns off the pivot for the dash vent.
Old Aug 26, 2014 | 08:07 AM
Seff's Avatar
Thank you, Oldspackrat, I'd forgotten the amount of screws.
In my experience, the think white stuff is water proofing around the vent (ask me how I found out...)
Old Sep 10, 2014 | 07:43 AM
wcourt3010's Avatar
how'd you find out?
Old Sep 10, 2014 | 07:47 AM
Seff's Avatar
I removed it, and subsequently my kick panels started leaking.
kansjfr
Nov 30, 2014 11:03 PM
ThePackRat
Jan 2, 2014 08:52 PM
costpenn
Jun 26, 2011 04:43 PM
msco123
Apr 3, 2010 10:51 AM
boese1978
Apr 20, 2008 03:30 PM
