Intake bolts wont stay seated
Working on Alice, and seems every morning I check to make sure that the bolts on my edelbrock intake I installed are staying where they should, seems that at least two of them are always loose.
I have been torquing them to 20fp and not sure how to keep them in place. any ideas?
I found that when using composition intake gaskets with the aluminum intake manifold that I had to retorque the intake bolts every week or so for a couple months until they quit loosening up on me. I think the thermal expansion of the aluminum intake crushes the gasket some, then when the intake cools the bolts are slightly loose. As I said, this eventually stopped after many retorque cycles. Just keep checking them and retorquing as necessary.
Re-torquing Edelbrock Intake Manifold
I also recently put new gaskets in and yes, the bolts will have to be re-torqued because I already have oil leaks, especially on the back side. I also removed the valve covers to paint them and the bolts are all loose too with some leaking as well. So I will have to re-torque everything. However, for the Performers intake, the instructions indicate 25 pounds of torque, not 20 or 35. For the intake leaks I will finger press more silicon by the leaking areas and then re-torque.
yeahbuddy
June 1st, 2012 02:33 PM
