Installing upper rear main seal
Old Oct 18, 2009 | 12:55 PM
Robert Kiedrowski's Avatar
rkiddo41olds
Am replacing the rear main seal on a 41 Olds 6 cyl. I have replaced these type seals before but never encountered a real problem. The new seal is correct but have failed to pull the seal through after numerous attempts. I am using the Chinese finger type of tool to pull the seal,but it keeps slipping out of the tool. I tried using the sneaky pete puller but it broke on the first attempt. Any suggestions.
Old Oct 19, 2009 | 06:01 AM
Oldsguy's Avatar
Past Administrator
Ouch! I have never had that difficulty before so can't specifically help you but best of luck. Moving thread for better exposure, hopefully.
Old Oct 19, 2009 | 06:18 AM
Oldsmaniac's Avatar
I tried as you did on a 59 394 engine. Could not pull it up and over. While pulling I had someone rotate crank manually and rolled the seal into place. I never checked the results after the job so I dont know if it worked or not.
Old Oct 19, 2009 | 07:07 AM
citcapp's Avatar
I have also installed a seal in this manner and it worked out fine
98regency
Jan 8, 2015 07:49 PM
toneypenna
Oct 7, 2010 05:19 PM
Gbobby
Mar 15, 2009 02:55 PM
65cutty
Sep 23, 2008 10:07 AM
gearheads78
Apr 17, 2008 05:03 PM
