Ignition advance references
Old April 12th, 2018, 01:18 PM
Seff's Avatar
Hello dear Olds guys.
I'm wondering if someone knows the factory timing figures for the various engines over the years? All the way from '64 to '90. Did they vary with compression? Did they vary with bore size? Did they vary with cam size? With wildaboutcars.com being pay-to-use, the info is not readily available.
Like so:
Engine CID:
Compression:
Bore:
Initial timing:
Total timing:
Vacuum advance:
Background:
I've recently acquired a 403 HEI for my 380 stroker engine, after my Chinesium HEI broke its advance mechanism.
Knowing a bit of combustion theory, I thought I'd try to figure out what the actual optimum timing is for my engine. The stroke, compression and bore has been modified, meaning that it doesn't necessarily need base 350 timing numbers. Ultimately I'd like to dyno tune the distributor - but that's down the road.
Thanks.
Seff is offline
Old April 12th, 2018, 05:42 PM
The advance curves for each distributor are listed in that year's Chassis Service Manual.
joe_padavano is offline
Old April 12th, 2018, 09:43 PM
Seff's Avatar
Yes, and I only have a 72. They used to be available on wildaboutcars.com, but nowadays they're behind a pay wall.
Seff is offline
pcard
February 11th, 2013 05:09 PM
Redog
June 21st, 2012 08:05 AM
adis
June 1st, 2012 06:48 AM
jad717
December 9th, 2009 11:11 AM
tmaleck
October 9th, 2009 12:57 PM
Quick Reply: Ignition advance references
