if anyone can help with a block #
Old Apr 4, 2011 | 07:26 PM
hotrodolds79's Avatar
i need to know what year these #s are 395558 2
an 8 on the heads.
where can i get a book at for the olds motors
i traded a chevy motor for the oldsmobile motor
Old Apr 4, 2011 | 07:35 PM
don71's Avatar
same but different
Thats a 350. Probably 1973-76.
Old Apr 5, 2011 | 06:40 AM
ok thank you
Old Apr 5, 2011 | 07:46 AM
Just to clarify a little, casting number 395558 2 was used on every Olds 350 block cast from 1968-1976, so it won't tell you anything other than displacement. The #8 heads were used for the 1973-1976 model years, but obviously those may or may not be original to the block. If the motor looks like it's never been apart and the intake has an EGR valve, it's almost certainly a 73-76 motor. If you care, check the VIN derivative stamp on the driver's side of the block, below the #1 spark plug. The second digit of the VIN derivative will be the model year the block was made.
Old Apr 5, 2011 | 10:38 AM
where can i get a book at for the oldsmobile motors?
so i can id the blocks
Old Apr 5, 2011 | 10:50 AM
You should check the tech section here, and get a factory manual. They can be had cheap on eBay if you watch for them.
Since your motor seems to be a '73 to '76, that's be a good range of years to choose from, though the basic engine info is the same for many years. I got my '73 manual for $8.
You should also join WildAboutCars, where you can download manuals until you buy one.
Old Apr 5, 2011 | 06:08 PM
thank you all. this is a big help
Old Apr 5, 2011 | 06:37 PM
Originally Posted by hotrodolds79
i need to know what year these #s are 395558 2 an 8 on the heads. where can i get a book at for the olds motors i traded a chevy motor for the oldsmobile motor
Good trade
You should also join WildAboutCars, where you can download manuals until you buy one. - Eric
You da man Eric! I was going to suggest this too except the part about joining other sites
Old Apr 5, 2011 | 06:59 PM
Well, you can actually download the manuals without joining, but it's free to join, and it seems only fair to do so, since that's all he asks in return for that wealth of information .
gws226
May 20, 2024 08:46 AM
68442
Jun 21, 2015 01:40 PM
mscofer
Apr 4, 2010 06:35 PM
joeh
Nov 12, 2009 11:56 PM
JetBoat455
Jul 9, 2008 02:51 PM
