ID 66-67 carb rods
ID 66-67 carb rods
Continuing to sort 66-67 parts collection.
I grouped similar looking rods for carburetors.
One or two seem like a generic not OEM rod.
Need to ID year and application for 2 vs 4 barrel and if there is a difference between transmission types based on the firewall kickdown switch/mechanism.
Thanks.
Mader
jm68442@yahoo.com
Which rod goes with kickdown throttle assembly?
Thanks.
Mader
jm68442@yahoo.com
A note on your A-body frame pads.
"A" is the 1964-68 (all engines) and 69 (SBO only) pad that uses the 2261 motor mounts.
"B" is the 70-72 (SBO) pad that also uses 2261 motor mounts. A and B are dimensionally equivalent and interchange, but for optical correctness, use the applications I've noted.
"C" is the 1969-72 (BBO) pad that uses the 2328 motor mounts.
Thanks Joe.
I'm good on BB/SB engine frame pedestal ID.
