ID 66-67 carb rods
Old Feb 25, 2023 | 03:39 AM
omy442's Avatar
ID 66-67 carb rods
Continuing to sort 66-67 parts collection.
I grouped similar looking rods for carburetors.
One or two seem like a generic not OEM rod.
Need to ID year and application for 2 vs 4 barrel and if there is a difference between transmission types based on the firewall kickdown switch/mechanism.
Thanks.
Mader
jm68442@yahoo.com
Which rod goes with kickdown throttle assembly?
Old Feb 25, 2023 | 06:40 AM
A note on your A-body frame pads.
"A" is the 1964-68 (all engines) and 69 (SBO only) pad that uses the 2261 motor mounts.
"B" is the 70-72 (SBO) pad that also uses 2261 motor mounts. A and B are dimensionally equivalent and interchange, but for optical correctness, use the applications I've noted.
"C" is the 1969-72 (BBO) pad that uses the 2328 motor mounts.
Old Feb 25, 2023 | 07:47 AM
omy442's Avatar
Thanks Joe.
I'm good on BB/SB engine frame pedestal ID.
Tri-Carb
Nov 27, 2021 12:15 PM
Jul 2, 2021 06:29 PM
May 3, 2021 05:45 AM
grannys442
Apr 24, 2021 07:12 PM
Charlie Jones
Nov 25, 2018 07:38 PM
