I need help Id'ing this engine/trans
Old Jun 2, 2009 | 03:15 PM
Karl's Avatar
Hello,
I just picked up a complete Rocket engine and trans at an action and was told it's a 55 or 56 Olds rocket. I'm not familiar with the early Olds engines at all and was wondering if you would help me decode this stuff. The verdict is still out if I'll keep it or sell it and use the money to work on other projects. Problem being is I have no idea what it's worth as a whole or parted out.
Here's the numbers:
The block on the back "bellhousing": CFO 257 a large 6 with 563922 under the six. It might be 568922 it's hard to tell. Also, on the driver's side of the bellhousing reads N3x. The passenger side reads 03x.
Heads: large 7 over center exhaust port. Under the cover on the top left corner reads CF 225. Under the cover, top right corner reads a larger 3 and 563974.
The four barrel intake: 563966
The trans has a slanted pan on it and reads: 8515013 8-26 cast into the passenger side of the case.
The carb is by Carter and the metal tag reads: 206s H4 This might be off a little, the tag is bent over the edge.
Any help would be great!
Thanks,
Karl
Old Jun 9, 2009 | 10:33 PM
59-59-59's Avatar
I cannot find these numbers for an Olds block from '53 to '62 . Plus i thought Olds used Rochester carbs that year anyways. I would like to see a picture if you can supply one
Old Jun 10, 2009 | 05:12 AM
Karl's Avatar
Ok. I'll send pics if I can get them to work.
http://i508.photobucket.com/albums/s.../3blowers2.jpg
oops! There I go dreaming again!
http://i508.photobucket.com/albums/s...k01/Engine.jpg
http://i508.photobucket.com/albums/s...01/Engine2.jpg
http://i508.photobucket.com/albums/s...01/Engine1.jpg
Let me know what you think.
Thanks,
Karl
Old Jun 10, 2009 | 05:44 AM
wmachine's Avatar
Trying to remember member
........and I was ready to help you id that first one......
Old Jun 10, 2009 | 03:26 PM
88 coupe's Avatar
Junior Member
Originally Posted by Karl
........ was told it's a 55 or 56 Olds rocket ........
'54-'56 trans.
'54-'56 Rocker covers.
'49-'55 distributor.
I know nothing about the numbers.
........ i thought Olds used Rochester carbs that year ........
Could have been made by Rochester or Carter, but they were/are the same carb .
Norm
Old Jun 15, 2009 | 08:05 AM
Karl's Avatar
I still don't have anything to work off of. What displacment, are #7 heads any good, is the trans a good one,...Anyone want to buy this thing?
Old Jun 17, 2009 | 02:01 PM
88 coupe's Avatar
Junior Member
........ What displacement, are #7 heads any good, is the trans a good one ........
324 inches, yes, and yes.
Norm
Old Jun 17, 2009 | 02:35 PM
chequenman's Avatar
engine size
Hey ... You got yourself A '56 Olds "324" now what you need is a buyer !!!
Old Jun 17, 2009 | 02:48 PM
88 coupe's Avatar
Junior Member
How do you know it is a '56, not a '55?
Norm
Old Jun 17, 2009 | 02:58 PM
chequenman's Avatar
OLD info
Norm
Olds cast the year numbers in the rear of the Blocks beside the Dist. They used Single Digit Numbers and the Blocks changed in appearance by the Decade so they didn't get confused with other Displacements. Things changed through time but this identifying mark was used in the '50s & '60s.
Old Jun 19, 2009 | 07:28 AM
Karl's Avatar
Ok. So now I have an idea of what I've got. Now, what would be a fair price to ask of such an item?
I've decided to focus on the 455 I've already started with and put the money into that. I'd be interested in a trade for things I need for the 455 such as a trans, heads, aluminum intake, carb...
I'll look and see were to better post this.
Thanks for all the help people!
Karl
Old Jun 19, 2009 | 08:06 AM
citcapp's Avatar
Post it in the parts for sale forum. You might want to post as a for sale or will trade for 455, parts, etc
Old Jun 19, 2009 | 10:34 PM
chequenman's Avatar
Answered ??
Karl
Hey, I hope Citcapp has answered your Question !!!
oldspackrat
May 27, 2015 07:31 AM
marxjunk
Sep 24, 2014 03:20 AM
gto65racer
Feb 21, 2013 02:59 PM
62radarlove
Feb 24, 2012 07:37 AM
6inarow
Oct 16, 2010 02:58 AM
