I need hei for a dumb *ss
Old Jul 15, 2011 | 12:53 PM
cluelesscutlass's Avatar
ok so i have a 72 cutlass with a 350. upgrading from coil to summit hei. cant i just take the power from the red wire that went to the coil? why dosent the hei have a ground wire?
Old Jul 15, 2011 | 02:06 PM
don71's Avatar
same but different
The hei needs a full 12 volts to function properly. That red wire you talk about may or may not be deliverying 12v. Check it with a voltmeter to be sure. If you use the old points wire, it many only deliver 8-9 volts, which is all points require, the hei has to have more.
It doesn't need a ground wire because it is grounded through the distributor body its self. There is a little tab inside that grounds the coil to the body. You don't need to worry about that.
joepenoso
Jun 4, 2014 01:56 PM
oldscruiser
Feb 15, 2011 12:44 AM
mr-tom
Jul 3, 2007 11:52 PM
GoldOlds
May 20, 2007 09:17 AM
mwmjr
Jan 29, 2007 05:28 AM
