how do i do front wheel bearing replacement on 1972 culass
Let us know if you have any problems, it's not very hard. When you have them out clean them up really good, inspect for pits on the bearings and races. If there is any doubt replace them, they're not very expensive.
Loose is obviously bad.
Too tight is bad.
Generally you tighten to a certain torque while rotating the wheel, then back off and bring it down tight again just until all play is removed, then line up the castle nut slots with a spindle hole [may be more than one to choose from].
Bearing in mind [ha ha] that within the hub is the outer RACE for the bearings, which to me is part of the bearing, and as such usually comes with the new bearing, but some folks insist on calling it a separate part. To remove those generally requires a long drift [punch, rod, dowel, etc.] and just tap it out by going 'round and 'round the thing until it comes out. Tap the new one in [or use the special driver if you have or can borrow one] in much the same way- being sure that it bottoms out in the cavity and sounds solid when you are done, like you are striking the hub itself.
Stuff the bearings full of the proper grease and off you go.
62 Cutlass Convert
Aug 12, 2015 11:35 AM
Flye
Drivetrain/Differentials
Jul 30, 2009 10:24 AM
