Horn
Old Aug 29, 2023 | 07:16 AM
7thof11's Avatar
Horn
I just bought my 72 cutlass and the horn is not connected. I've been on you tube and can't find my problem
Where does the wire connect?
Please help
Old Aug 29, 2023 | 08:05 AM
mpowell's Avatar
Are you just trying to connect it or troubleshooting why it is not working? I don't see your turn signal canceling cam which is needed to complete the circuit. Please elaborate on your issue.
Old Aug 29, 2023 | 08:08 AM
7thof11's Avatar
Well, that's helpful. Why would someone leave that out
Old Aug 29, 2023 | 08:20 AM
mpowell's Avatar
They can get a little crunchy on these old cars. Likely broke and never got a replacement.
Old Aug 29, 2023 | 08:23 AM
7thof11's Avatar
Thanks, found 1 on ebay with free shipping
Old Aug 29, 2023 | 05:51 PM
7thof11's Avatar
Would that have anything to do with the backup lights? I have a manual transmission
Old Aug 29, 2023 | 06:38 PM
mpowell's Avatar
Here are a couple threads on this site that may help.
Reverse light help - ClassicOldsmobile.com
1972 Cutlass reverse switch 4 speed - ClassicOldsmobile.com
Old Aug 29, 2023 | 06:53 PM
Your first photo indicates that a number of pieces are missing. There is a spring that goes over the steering shaft, then the cancel cam, then the lock plate, the snap ring, and the cover plate with three retaining screws. See items 2 through 6 in this diagram. You will need a lock plate spring compressor tool to reinstall that snap ring.
Old Sep 19, 2023 | 01:15 PM
7thof11's Avatar
Horn issues still
This is where the part goes
Does anyone know what this part is called?
Old Sep 19, 2023 | 01:17 PM
That is the switch for the key-in-the-ignition buzzer. If you don't want to hear that annoying buzzer, just leave it out.
Old Sep 19, 2023 | 02:41 PM
7thof11's Avatar
It has nothing to do with the horn whatsoever?
Old Sep 19, 2023 | 02:44 PM
If it did, I would have told you that.
Old Sep 19, 2023 | 02:57 PM
7thof11's Avatar
I have power going up the steering column but no power to the button that the cancel cam glides over it to blow the horn.
Old Sep 19, 2023 | 03:22 PM
That wire provides ground, not power. The power to the horn relay comes from the red wire on the threaded post. The black wire to the steering column is the ground side of the circuit. When you press the button, this wire is shorted to ground (the steering shaft), which energizes the coil in the relay and operates the horn. Simply jumper from the horn contact post to ground. The relay should at least click.
Old Sep 20, 2023 | 06:42 AM
7thof11's Avatar
Joe or anyone, this wire was just sitting at the firewall taped up. Any clue to what it's supposed to be connected to?
Old Sep 20, 2023 | 06:49 AM
That's an interesting mess you have there. The larger connector APPEARS to be the kickdown harness plug that is supposed to connect to the transmission. One of the wires has clearly been cut. The jumper that plugs into it appears to terminate in the connector for the brake differential pressure switch. Where does the wire into the larger connector go, and what color is it?
Old Sep 20, 2023 | 07:06 AM
7thof11's Avatar
That's just one black wire that looks like it's heading towards the manual transmission
Old Sep 20, 2023 | 07:08 AM
7thof11's Avatar
Electrical is not my strongest point on cars and I can't find anyone locally to look at it. I'm in Woodbridge VA which is about 30 miles south of DC
Old Sep 20, 2023 | 07:13 AM
I'm in Loudoun Co, near Lovettsville. Wipe down that black wire. Is it really black with an orange stripe? That would be the trans kickdown wire for the AT. It was included in every harness no matter which trans was selected. The other wire that's been cut off should be green. Trace it again. The other end of the wire should be at the firewall connector.
Old Sep 20, 2023 | 07:25 AM
7thof11's Avatar
it's just a solid black wire, no stripe. I disconnected it just to let you see it. I don't see a cut green wire
Old Sep 20, 2023 | 07:26 AM
7thof11's Avatar
And the wire follows the power wire towards the starter
Old Sep 20, 2023 | 07:44 AM
Well, in any case, that's the wire for the Transmission Controlled Spark sensor in the trans, and yes that part should be black. That wire originally ran to the TCS Thermal Vacuum Switch that was screwed into the intake. Someone has rewired and repurposed it for an unknown reason.
Old Sep 20, 2023 | 07:47 AM
7thof11's Avatar
Are you a working mechanic?
Old Sep 20, 2023 | 07:49 AM
Nope. Just a hobbyist with a full time day job.
Old Sep 20, 2023 | 07:53 AM
7thof11's Avatar
Thanks for your input
Old Sep 28, 2023 | 05:57 AM
7thof11's Avatar
Here is my history of the horn and back up lights. The car came without a cancel cam and retaining ring and no reverse lights. I put in a bad review on Google about my experience with the dealership that I purchased from. They contacted me immediately. They didn't return my calls prior. With an extensive conversation with the mechanic, they sent me a new reverse switch, cancel cam,retaining ring and horn relay. I have reverse lights, no horn. More conversation with the mechanic. The brand new horns that were in the car were no good and the turn signal switch where the brass spring loaded button in was shot. It did not have enough spring in it anymore to hit the cancel cam. Horns were easy to replace, turn signal switch was a lot of fun. It didn't line up to the old harness. I had to cut at the gap near center and shave the ends to get it to go in. After a lot of shaving it was in. Put everything back together and tooted my horn. What a wonderful sound. Then I started my car and put it in neutral to check my turn signals, the horn started honking. We are at a loss as of why. Any ideas?
Edit
Old Sep 28, 2023 | 10:49 AM
7thof11's Avatar
Apparently the new turn signal switch was the issue. I fixed the old one with the bad spring and everything is AOK.
Aug 2, 2018 05:04 AM
sealw98
Jun 16, 2016 06:32 PM
neatolds
Oct 16, 2015 08:27 PM
Promethean
Oct 19, 2012 03:45 PM
redvettemike
Aug 15, 2009 07:04 PM
