Holes on top end of olds 350
Old Mar 28, 2021 | 07:41 PM
W31cutty's Avatar
Rebuilding a olds 350. Under the intake there are 2 holes. One goes to the #2 cam bearing the other goes to the #4 cam bearing. What are these holes for? My cam bearings only have 1 hole. Should they face the crank or the top end holes?
Old Mar 28, 2021 | 08:43 PM
66SportCoupe's Avatar
Nothing to go there with later blocks
Old Mar 28, 2021 | 09:48 PM
On earlier blocks those were threaded and used to hold the oil splash tray.
Old Mar 28, 2021 | 11:01 PM
Owen Miller's Avatar
Holes
I thought only big blocks had the splash tray.
Old Mar 29, 2021 | 05:13 AM
The 1964-67 330 motors used a three piece intake gasket - separate metal embossed gaskets around the ports and a large center tray that was held with those fasteners. It's not the same as the little deflector used on the BBOs. And of course the later roller cam motors (gas and diesel) use those holes to retain the spider for the roller lifters.
Old Mar 29, 2021 | 06:12 AM
W31cutty's Avatar
Its a 70 block. They are not threaded, and I can see the cam bearings when looking in the holes. My concern is, do I have the right cam bearings? Should there be 2 holes in the bearings, 1on top and 1 on bottom? Why are the holes there? If they don't feed oil to the cam then oil would just sit in the holes and do nothing, whats the point of that.
Old Mar 29, 2021 | 06:39 AM
67OAI's Avatar
Old(s)GuysRule
You do not want the holes in the cam bearings to face those holes in the block. The holes in the cam bearings face the crankshaft for proper pressurized oil delivery to the camshaft bearing.
Old Mar 29, 2021 | 06:43 AM
If there were two holes in the cam bearings, that would be an oil leak and you'd have no oil pressure.
Old Mar 29, 2021 | 06:50 AM
oddball's Avatar
Just leftovers from earlier versions of the mold. They don't change details of the mold making stuff unless they need to.
The hole in the bearing faces the oil feed, which comes from the main bearing - so the hole in the cam bearing faces down. Your machinist that's installing the bearings will know this.
You don't want an extra hole in the bearing. It would just spit away oil.
Old Mar 29, 2021 | 07:54 AM
W31cutty's Avatar
Thanks for the info everyone
rothlane'68
Mar 14, 2021 04:56 PM
Kadman
Jun 2, 2020 04:03 AM
Majic Jack
Aug 11, 2015 10:44 AM
steverw
Jul 22, 2013 01:06 PM
Seff
May 17, 2013 11:35 AM
