394 crankshaft!
Old Mar 24, 2021 | 02:14 PM
59oldsthunder!'s Avatar
394 crankshaft!
Well I just rebuilt this 59 394 oldsmobile an it started knockin shortly after,2 rods spun bearings ug sucks so heres a few pics after took back apart anyone know if my journal can be turned or is it scrap? Help!!!
Old Mar 24, 2021 | 02:24 PM
Sugar Bear's Avatar
That rots, sorry it happened.
​​​​​​First order IMO is to find the cause. If the crank was standard and oversize bearings are available e.g., .030" then it can probably be salvaged. Only remove the minimum amount of material needed from the crank for which bearings are available. If .020" will suffice and those bearings are available do that.
Old Mar 24, 2021 | 03:12 PM
Crank
Ya that be good so wonder if oil lines got plugged on that journal? Heres a pic of whats left of part of bearing half one rod had no bearing left at all crazy so as long as can be turned thats good know!
Old Mar 24, 2021 | 03:13 PM
Bearing!
Old Mar 24, 2021 | 03:33 PM
Sugar Bear's Avatar
In addition to crankshaft resizing, the connecting rods will need corrective machining or possibly replacement.
Old Mar 28, 2021 | 06:04 PM
Tedd Thompson's Avatar
That's a lot of bearing junk that went somewhere, hope it works out OK.... Tedd
Old Mar 28, 2021 | 06:41 PM
2blu442's Avatar
If you end up needing a crank I've got a couple.
John
Old Mar 29, 2021 | 12:24 PM
Crank
Hey John whats up,ya there was shavings in oil a bunch got a pic if can find it so u habe a 394 crank? Thats good 2 know is it a 59 or 60? The later years 394's cranks had wider no1 main cap bearings,will know soon if its gonna fly! Fun stuff ha! Thx wayne!heres what was in oil crazy!
Old Mar 29, 2021 | 12:57 PM
2blu442's Avatar
Ouch! I saw your previous picture of the remains of a bearing! Not sure what years I have, but if you do end up needing one I can get the casting numbers off them and take any measurements you'd need to know if I have the correct one or not.
59oldsthunder!
Jun 9, 2021 03:57 PM
2blu442
Mar 15, 2021 04:03 PM
twiggy
May 17, 2020 11:11 AM
KQQLCAT
Dec 22, 2019 10:09 AM
