Help ID a restamp?
Old October 6th, 2018, 01:58 PM
BSiegPaint's Avatar
Help ID a restamp?
i bought a rebuilt carb a year ago and it was immediately apparent that it was a restamp when I got it. It’s a beautiful restoration, and it works great on a 455 (pig rich on a 350), but since I now have the right carb on my car, I’d like to sell this one. However without the original numbers, I have no idea where this would belong. Can anyone help me ID this based on markings, configuration, or other methods? I’ll post a few pics, but I have more. Thank you!
BSiegPaint is offline
Old October 6th, 2018, 07:45 PM
I can't help with the markings. All I can say is if you can get the primary jet, primary and secondary metering rod, and secondary rod hanger numbers, someone may be able to figure out its application.
Fun71 is offline
Old October 6th, 2018, 08:54 PM
66-3X2 442's Avatar
The stamp says it's a 70 W-30 stick carb.
66-3X2 442 is offline
Old October 6th, 2018, 09:16 PM
4speed455's Avatar
I don’t need a matching numbers carb but I have been wanting to switch my edelbrock on my 68 455 out with a Quadra jet. PM coming.
4speed455 is online now
Old October 6th, 2018, 09:31 PM
same but different
don71's Avatar
Yea I think we get that, but I think the question is "what do the part numbers of the guts mean it is"? Those might lead to what the final assembly is built to be reproduced as.
I wish I could tell a re-stamp form one that isn't. I sure cant tell. And thats where the internal parts might lead to more in the investigation regardless of external bowl stampings.
don71 is offline
Old October 7th, 2018, 03:14 AM
rob1960's Avatar
The stamping looks good & the "UA" code is correct, but I'm no expert. If it's a true "256" carb it won't have a power piston or primary metering rods,they came from the factory with #58 front jets. I'd pull the air horn & check it out. Also at the front of the throttle plate there won't be a staked in plug for the part throttle power piston adjustment, it was just a bare casting. I posted a pic of my '68 Qjet with a circle showing the plug. Your choke pull-off linkage rod is on backwards & upside down by the way.........
rob1960 is offline
Old October 7th, 2018, 04:24 AM
delete
droptopron's Avatar
Originally Posted by don71
I wish I could tell a re-stamp form one that isn't..
I think what the OP is alluding to is that the 256 looks crisper and deeper than the 7040
Re OP - Now that its re stamped I don't know if it matters what the orig application was. Just list it as a a good running carb tuneable for your application
droptopron is offline
Old October 7th, 2018, 05:10 AM
BSiegPaint's Avatar
Thanks, everyone - this is the info I was looking for, to a great degree. Yeah, as far as the restamping goes, there is a kind of patina to the metal everywhere on the carb except where the stamping is, and that spot is too perfect, in my opinion. That stamp is a little too crisp and deep compared to others I have or have had. I'll pull the air horn this morning and see if there is a power piston and primary rods, and I'll check to see what jets are in there. Rob1960 noted there shouldn't be a plug on the front of the carb throttle plate, and there is. And good catch on the choke rod being on wrong. I'll get all the numbers I can so I can at least in good faith get it to someone who can use it. 4speed455, I got your PM and I'll answer you later this morning when I have a little more info.
Old October 7th, 2018, 07:26 AM
BSiegPaint's Avatar
Ok, I pulled the air horn and there are no primary metering rods or power piston. The front jets are 58s. The secondary hanger is an “O” and the rods are “BE”. So it appears the carb was set up to run on a W-30/31, but I’m not convinced this is the real deal. And I flipped the choke rod as it is supposed to be...
Old October 8th, 2018, 03:03 AM
rob1960's Avatar
The correct factory rear rods were "AU"s They were used in every '70 carb except a standard 350 4bbl which used ATs
rob1960 is offline
Old October 8th, 2018, 06:47 AM
costpenn's Avatar
Is it just me or does the 256, UA, and 3329 digits look raised - in other words- molded in like the identifying letter on a cylinder head?
costpenn is offline
Old October 8th, 2018, 07:03 AM
edzolz's Avatar
Optical delusion. The entire body would have to be re-cast for these to be raised letters.
edzolz is online now
Old October 8th, 2018, 11:35 AM
BSiegPaint's Avatar
I really appreciate everyone's input on this. I learned a bit more about the Quadrajets as I dug into this more. Really it's all about the internals - what jets and needles at what height - and the carb configuration changed very little over the years. For those that have been asking, I did sell this particular one to another member here, but I appreciate the inquiries.
1bad442
August 2nd, 2021 10:05 AM
nj_cutlass72
April 13th, 2019 05:52 AM
allyolds68
January 20th, 2019 04:30 AM
JIM'S w30
November 28th, 2018 05:50 PM
69442murph
October 29th, 2018 09:10 PM
Quick Reply: Help ID a restamp?
