HELP! Flooding inside car!!
Old Aug 6, 2018 | 08:54 AM
Had a great time at Gettysburg but rain was a huge pain. Twice we got 2-3 inches of water in the drivers side floor board of our 71 Cutlass Convertible.. The second time my wife and I were in the car and it was clear that the water was not coming from the roof, but the water was getting deeper under my feet as it continued to downpour. Today I removed the seats and carpet to get them dried out and figure this out. I was pretty sure the problem was in the rear with the roof trough but that seemed ok as wifey ran a garden hose around the rear of the roof and I looked in trunk and rear seat area. So we went to the front and found the issue. As she ran water in the cowl area under the rear edge of the hood it poured right in to the drivers floor thru the kick panel area. I removed the interior kick panel as she ran water and it comes right out as a flood. We checked the passenger side the same way and it doesn't do it , the water goes out the bottom of the car. I hope you can see it in the pics. I hope it's something easy like a clogged drain, maybe?? I sure hope you guys can help with this, car is still apart and drying out with fans in the garage. Thanks so much, Greg
Old Aug 6, 2018 | 09:36 AM
Gary M's Avatar
Your leak may be down inside the air feed. Take off the screen on top the cowl and shine a light down inside.
Can you make sure water didn't get into the wire protector running across the floor?
Old Aug 6, 2018 | 09:59 AM
MI68442W30's Avatar
your leak is most likely your kick panel is no longer sealed to the cowl, once a kick panel is removed you have to reseal with new strip caulk if you don't want it to leak on your floorboards .
Old Aug 6, 2018 | 10:47 AM
The cowl drains are designed to drain that water. Seals or not, there shouldn't ever be enough water in the lower cowl to flood the interior. You've got clogged drains.
Old Aug 6, 2018 | 12:03 PM
RetroRanger's Avatar
72 Olds CS
where are the drains ? I was gonna post this same problem but Greg beat me to it, I was caught in recent heavy rains and both the drivers and passenger side had wet floors the water seemed to come from behind the kick panels.
I have had my fenders off before and there wasnt any debris behind them
Old Aug 6, 2018 | 12:12 PM
The debris is inside the lower cowl, not between the cowl and the fender. Read this thread about a similar problem in a Chevelle.
Old Aug 6, 2018 | 06:46 PM
MI68442W30's Avatar
with all due respect , even with no debris in the inner cowl ,and the water drains out as it should ,if the kick panel is not sealed it WILL leak water on the floor and in a heavy rain it will accumulate rapidly, do yourself a favor and pull the kick panel and you will see the thick factory strip caulk that seals the kick panel vents, as they stick out into the inner cowl where the water will run and drip onto it and leak around it . no if ands or buts about it.
Old Aug 6, 2018 | 07:37 PM
oldsconv's Avatar
Agree with above. My chevelle had same issue. Kick panel protrudes into cowl side panel. Rain water runs down and on top of the plastic vent " tube"and collects and leaks into passenger compartment. I had no issue with clogged drains and water was not backing up or rising up in that area to cause the leak. I had removed these during interior work and started leaking and they never leaked before. I resealed it with strip caulk and problem solved. You may have a different issue like clogged drains that could cause an issue, but definitely check this possibility also.
Old Aug 6, 2018 | 08:01 PM
What blocks the vent hole in the drivers side in an AC car?
Old Aug 6, 2018 | 09:26 PM
That is a good question. The DS kick panel is very flimsy and is held on with one screw, so that won't hold it tightly enough to the cowl to make a water tight seal - it's just a cosmetic panel. Heck, someone put a second screw in mine just to keep it from rattling around.
Old Aug 6, 2018 | 11:36 PM
Gary M's Avatar
this was what I was thinking but how do you clean them out? The Chevell site ( unless I missed it ) did not tell. I would assume the drain holes would be at the bottom. It showed a Sh*t ton of trash but how do you get it out?
Old Aug 7, 2018 | 05:25 AM
Thanks, guys. Now I have something to look for. A friend recommended using one of those telescopic probe cameras to look down in there, cuz you can't see from the top. I'll go look at it today. Greg.
Old Aug 7, 2018 | 09:33 AM
My442's Avatar
You may have rust through under the bottom of the windshield.
Old Aug 7, 2018 | 09:34 AM
My442's Avatar
Take out the inner fenders and use the square access hole.
Old Aug 7, 2018 | 09:54 AM
Bfg's Avatar
Bfg
I had this same problem with my Cutlass back in the 80's. I wound up putting in a small bilge pump. Finally the floors were so rusted they drained out on there own.
Old Aug 7, 2018 | 12:39 PM
72 Olds CS
LOL i guess ill just wait then ...gonna be a while cuz i just put floors in !!!
Old Aug 7, 2018 | 05:05 PM
bccan's Avatar
The driver side cowl/hinge pillar on AC car has a steel plate screwed on to seal the opening. I just put kick panel speakers in friends 72 442 so it’s fresh in my mind.
Agree on sealing of kicks on non AC car being a potential leak as well as clogged drain slots.
Old Aug 7, 2018 | 10:03 PM
Gary M's Avatar
Go for the drains. Bilge pumps lead to rust holes apparently. LOL
Old Aug 8, 2018 | 04:12 AM
I'm thinking about putting a sump pump in the drivers floor board, problem is I wont have room for my feet and the long extension cord would be a pain. Oh wait, I could put a generator in the trunk for the 110 volts! Yeah that's it! Seriously, I just had the windshield replaced so I know that's ok. I'll get back to it and let you know what I find. I think Joe is probably right- clogged drain, we'll see...
Old Aug 8, 2018 | 02:08 PM
A 12 Volt marine bilge pump would be easy to install...
Old Aug 8, 2018 | 06:35 PM
Yellowstatue's Avatar
At the bottom of the cowl is a one inch hole opening into the rocker panel. Leaves, pine needles, dirt, sand, anything that can fit through the cowl screen, if it has one, will eventually collect at the bottom of the cowl and cover the one inch drain hole. I cleaned mine out with the vacuum and a long screw driver to antagonize the collected debris and used a trouble light and mirror to evaluate how effective my assault was. Mission accomplished.
Old Aug 13, 2018 | 05:15 AM
Well, I got back to it . There is a oval plate that screws to the inside of the cowl behind the plastic kick panel. I had to remove the park brake assembly and then could remove the 4 screws to remove the plate. There was no debris in there like the pic on the Chevelle site. There was no hole (drain) at the bottom. I do remember back in 2000 when car was restored the bottom of both side cowls were rusted out. I had the car restored and didn't do it myself but I was able to go over and check it out and I remember he rebuilt the bottom of the cowls with sheet metal patches. Now I can look in there with a inspection mirror and see the mig welds and the patch with no drain hole in it at all. I decided to take apart the passenger side to see what it looked like but found the air intake for the A/C on that side so I couldn't see down in there. (Actually it probably doesn't have a drain hole either as I now think I remember he rebuilt both sides) He has since passed away so I can't ask him if he remembers.... I pulled the 2 bolts on the bottom of the fender and can see/feel the bottom of the cowl and again there is no drain hole. I then scoured the assembly manual, service manual, and Fisher Body manual and couldn't find a picture or drawing of the bottom of cowl. I have been considering drilling a hole in his repaired areas but I really hate to do it. Seem like a hack job. Does any one have any pics or drawings that show how the factory drains are? Or any other advice? Thanks again, Greg.
Old Aug 13, 2018 | 09:16 AM
Gary M's Avatar
Did you remove the inner (fender well) like MY442 suggested yet?
Old Aug 14, 2018 | 05:12 PM
No I haven't removed the inner fender, you know how these things can go, one thing leads to another and MAW's ! I could end up restoring the car again! I took my Vista Cruiser over to a friend's last nite and put it on his lift to take pics. The lower rear of the front fenders are rusted out and I could feel up onto the cowl and feel a hole with my pinky. I'll look thru some build threads and hopefully find a pic. Thanks again.
Old Aug 14, 2018 | 10:01 PM
Gary M's Avatar
I know exactly what you mean
my car is slowly becoming a full restoration. MAW while mines this far apart paint it etc etc.
Old Aug 15, 2018 | 07:14 PM
Exactly...
BlueCalais79
May 30, 2017 03:35 PM
DeltaDevil88
Aug 3, 2013 04:48 PM
nightmare
Nov 4, 2011 05:30 AM
CQR
Aug 18, 2011 12:52 PM
Oldsmofjord
Jul 30, 2007 04:58 AM
