Headers for performance 455 in a delta 88
Old April 19th, 2017, 04:45 PM
turley68delta88's Avatar
Hey I have a 1968 Delta 88 with a built up 72 455 engine from a Cutlass and I bought these headers off of eBay that don't seem to fit and I've done some research and can't seem to find any right fitting headers for my car because of how these cars were made and that any set of headers is going to take some adjusting to fit in there/ I was wondering if any shorty headers might fit or if there is any specific header that would fit exceptionally better or if there's a way I can make these headers fit, they're from a seller off of eBay called tcboverstock and they were cheap and this is the last thing I need done have this engine finished any help would be greatly appreciated it's been a long journey getting this car done finding all the right parts and making them work, thank you!
turley68delta88 is offline
Old April 19th, 2017, 06:15 PM
Oldsmaniac's Avatar
I would be surprised if they were even Oldsmobile headers? Guys are now advertising Chevy headers fitting Olds. No they dont make headers for this car. The passenger side will prob fit but the driver's side is where the trouble is due to the steering box. With enough cutting and welding there is a possibility the header could be modified, I would not want to try it. Just get the repro factory left side manifold for duals and get it done.
Oldsmaniac is offline
Old April 19th, 2017, 06:27 PM
okay yeah it seems like that would be my best option because I don't want to wait any longer and keep messing with stuff thank you very much👍
Old April 20th, 2017, 05:46 AM
Here's a link to the reproduction dual exhaust manifold for the 65-70 B/C bodies.
http://thorntonmusclecars.com/produc...aust-manifolds
You can cap the passengers side manifold where the crossover was at or you can have it welded by a competent welder.
Olds64 is offline
Old April 20th, 2017, 06:34 PM
Kennybill's Avatar
Thornton's repopped factory S is the only aftermarket manifold available for the B/C bodies. It's shaped like that to clear the rear steering box and the rare manual shift B-bodies to clear the Z-bar also. Back a dozen years ago no one was repopping the factory S manifold. My Turquoise 1967 98 has Toronado manifolds. Passenger side is factory with no extra outlet. Drivers side is cut, rotated and ni-welded. Very smooth transition on the inside. A little grinding was needed to make it work. It has 2.5" pipes with a torque tube.toroexhaustandshifter002-1.jpg
Kennybill is offline
Old April 21st, 2017, 05:17 AM
Kenny, that's the exact same thing my father and I did on his 69 Delta 88 years ago. We weren't aware of the Thornton's reproduction manifold at the time. I've mentioned it on our site before. I'm glad it worked for you. Very cool!
Olds64 is offline
Old April 21st, 2017, 06:07 AM
Kennybill's Avatar
Yes, this was before Thornton's and the factory manifolds were rare as "hen's teeth." The factory crossover pipe is usually smashed. I've always thought it's a good thing they had the intake manifold crossover to help get the exhaust gas over to the passenger side if the crossover is collapsed. A-body guys have it so easy, ha ha.
Old April 21st, 2017, 06:20 AM
Kennybill's Avatar
Thanks to "double trouble" my Turquoise 98 creating an "air depression."
Old April 21st, 2017, 06:28 AM
Ain't it the truth!
Oh yeah!
Olds64 is offline
Wyze
March 18th, 2012 01:59 PM
dp442
February 15th, 2011 04:22 PM
wmachine
December 30th, 2009 05:55 AM
projectheaven
February 22nd, 2008 04:36 PM
Yuneek
August 5th, 2006 01:20 AM
Quick Reply: Headers for performance 455 in a delta 88
