Harmonic balancer
Old Feb 6, 2018 | 03:45 PM
scrappie's Avatar
Harmonic balancer
1970 442 w-30. When looking at my harmonic balancer I see there is an outer and inner part separated by a rubber seal? This one seems to have let go and needs a rebuild or replacement. Are harmonic balancers matched or balanced to that particular crank or rotating assembly when built or are all 455 harmonic balancers the same? I have a 455 core motor with good balancer I could just switch or would the proper way to fix be rebuilding this one? I would still think it would need to be balanced ?
Old Feb 6, 2018 | 06:28 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I sent the one on my 54 to Damper Dudes and was very satisfied. Here is the link.
http://www.damperdudes.net/
I know there are some other companies that folks on here have used and been very satisfied.
Old Feb 6, 2018 | 06:32 PM
scrappie's Avatar
Thx for that any info on the questions I have?
Old Feb 6, 2018 | 06:58 PM
The stock balancers are balanced to the same requirement. You can swap them.
Old Feb 7, 2018 | 04:04 AM
scrappie's Avatar
Thx Joe
rroth01
Dec 3, 2016 06:27 AM
Gert3116
Apr 23, 2008 08:53 AM
bmbraun
Feb 25, 2005 12:17 PM
martine
Apr 2, 2004 09:25 PM
Clint Reno
Aug 10, 2003 10:03 PM
