Ground Wire location For 72 Cutlass Supreme
Old Apr 28, 2021 | 06:14 AM
Neuby7297's Avatar
My gas gauge is always reading above Full. Thinking bad ground or broken ground. Where is the ground wire terminated at? In trunk,bumper, or frame.
Old Apr 28, 2021 | 07:06 AM
jaunty75's Avatar
The ground wire comes off the top of the sending unit and is connected to the chassis somewhere up under the car forward of the fuel tank. You're going to have to get down under the car to look for it. It's probably worth putting the rear up on jack stands so you have more room to get your arms up in there.
This figure is from page 8-14 of your '72 Olds chassis service manual. Note "view C."
Old Apr 28, 2021 | 07:26 AM
The fuel level (float) sensor is the ground side of gauge circuit. Generally you have lost ground to the float, or its bad.
Old Apr 28, 2021 | 10:40 AM
A break in the wire between the gauge and sending unit will have the same symptom. On my car, the signal wire was loose at the sending unit, and the ground wire was fine.
yamahondarider
Jan 16, 2014 02:32 PM
Icee5150
Sep 1, 2013 10:16 AM
Tedd Thompson
Jul 25, 2012 02:06 PM
knighthawk
Jul 22, 2011 09:11 PM
Pete77
Jul 9, 2006 03:11 PM
