going crazy over oil leak
If there's oil leaking out of the breather either there is no pcv or its not properly hooked up. I just went through this, the breather is where fresh air comes in not blowby coming out.
Check to make sure that your vent cap (where you put the oil in) is clean. It is could be clogged pressurizing the pan and forcing oil out. Rinse in a coffee can or similar metal container with white gas or similar cleaner. Often overlooked on these engined
AS mentioned above, make sure your breather is clean, you can wash it out with keroseen or varsol, and gently blow it dry! Also make sure your vent tube is not full of ^%$$% also!
There is a mod to put a pvc in your fill tube, and do away with the vent tube in the back by installing a freeze plug.
more info
Got underneath her and noticed the road draft tube was missing filter. Could this cause oil to leak out due to not enough back pressure? it was on there the last time I was under.
