going crazy over oil leak
Old Oct 7, 2011 | 09:30 AM
rl55s88's Avatar
leaking oil out of rear engine breather on my 324ci. Does anybody know why? driving me crazy
Old Oct 7, 2011 | 10:06 AM
Does it have blowby??
Old Oct 7, 2011 | 11:01 AM
455man's Avatar
Does it have PCV? Too much pressure in the crankcase like oldcutlass is talking about?
Old Oct 7, 2011 | 11:11 AM
DJS70cutlass's Avatar
If there's oil leaking out of the breather either there is no pcv or its not properly hooked up. I just went through this, the breather is where fresh air comes in not blowby coming out.
Old Oct 7, 2011 | 11:42 AM
I believe his has a vent tube!
Old Oct 7, 2011 | 12:56 PM
rl55s88's Avatar
vent tube
thanks for feed back but no pcv it has a vent tube behind intake manifold on block that runs down to bottom of engine.
Old Oct 7, 2011 | 01:04 PM
citcapp's Avatar
Check to make sure that your vent cap (where you put the oil in) is clean. It is could be clogged pressurizing the pan and forcing oil out. Rinse in a coffee can or similar metal container with white gas or similar cleaner. Often overlooked on these engined
Old Oct 7, 2011 | 01:26 PM
AS mentioned above, make sure your breather is clean, you can wash it out with keroseen or varsol, and gently blow it dry! Also make sure your vent tube is not full of ^%$$% also!
There is a mod to put a pvc in your fill tube, and do away with the vent tube in the back by installing a freeze plug.
Old Oct 7, 2011 | 01:42 PM
rl55s88's Avatar
checked oil cap
Oil cap is clean but the fill tube looks clogged, how do you clean that?
Old Oct 7, 2011 | 02:04 PM
It's a slip fit, but very tight!!!!!! Btw when was the last time this motor was apart??
Old Oct 7, 2011 | 02:47 PM
rl55s88's Avatar
Bought it 3 years ago, dont know history of her. just that it had sitting for years and had blowen head gaskets. installed new and havent had problems till now.
Old Oct 7, 2011 | 04:01 PM
Oldsguy's Avatar
Past Administrator
Welcome to our site, moved thread due to technical content question.
Old Oct 10, 2011 | 07:30 PM
rl55s88's Avatar
more info
Got underneath her and noticed the road draft tube was missing filter. Could this cause oil to leak out due to not enough back pressure? it was on there the last time I was under.
hicksboy
Sep 10, 2013 03:43 AM
Soulblood
Mar 23, 2012 10:08 AM
Firstcutlass
Aug 31, 2011 07:07 PM
MHENDERSON
Dec 9, 2010 06:08 AM
silverriff
Mar 18, 2010 12:44 PM
