Generator - setting polarity causes it to run by itself
This happened with a new Delco voltage regulator. I forgot to set polarity on it. When I swap back my old voltage regulator, it spins during the brief moment I set polarity at the regulator.
I know I messed up my not setting it when I changed the regulator. The Delco won't stop spinning the generator which smoked my generator as the belt was holding the pulley. What is going on here? Pretty sure I smoked the Delco voltage regulator which is why its just permanently spinning the generator. Just looking for confirmation. Thanks.
yes, its scary as you wont know until your generator smokes overnight with power to it. I guess I am going to test for hot at the armature post on the generator after I shut the engine off, after a voltage regulator swap.
Was it not charging?
I wanted the correct Delco unit in it. It had an old off brand someone installed years ago. I am already thinking of just putting the Delco lid on it and be done. Ive never had a car with a generator except for '60 Falcon I just did an alternator conversion. The generator spinning with the engine off was a new experience for me!
Paint your old regulator silver, swap covers, and get your "smoked" generator rebuilt,
