Generator - setting polarity causes it to run by itself
Old Mar 8, 2023 | 09:00 AM
madmax442.com's Avatar
madmax442.com
This happened with a new Delco voltage regulator. I forgot to set polarity on it. When I swap back my old voltage regulator, it spins during the brief moment I set polarity at the regulator.
I know I messed up my not setting it when I changed the regulator. The Delco won't stop spinning the generator which smoked my generator as the belt was holding the pulley. What is going on here? Pretty sure I smoked the Delco voltage regulator which is why its just permanently spinning the generator. Just looking for confirmation. Thanks.
Old Mar 8, 2023 | 09:24 AM
Charlie Jones's Avatar
Phantom Phixer
You only need to flash the wires to set the polarity of the generator.
If the new Delco regulator spins the generator, it is defective. (stuck relay)
New is not always good.
Old Mar 8, 2023 | 09:28 AM
^^x2^^
Several videos & 'how to' articles on how to flash a generator to set polarity.
Old Mar 8, 2023 | 09:39 AM
madmax442.com
yes, its scary as you wont know until your generator smokes overnight with power to it. I guess I am going to test for hot at the armature post on the generator after I shut the engine off, after a voltage regulator swap.
Old Mar 8, 2023 | 04:39 PM
Phantom Phixer
Why did you swap regulators in the first place?
Was it not charging?
Old Mar 8, 2023 | 04:49 PM
madmax442.com
I wanted the correct Delco unit in it. It had an old off brand someone installed years ago. I am already thinking of just putting the Delco lid on it and be done. Ive never had a car with a generator except for '60 Falcon I just did an alternator conversion. The generator spinning with the engine off was a new experience for me!
Old Mar 8, 2023 | 05:06 PM
Phantom Phixer
That's what I was going to suggest.
Paint your old regulator silver, swap covers, and get your "smoked" generator rebuilt,
Bee Saint Louis
Nov 11, 2016 04:52 PM
kds 69 442
Oct 23, 2013 02:35 PM
R_CK_R
Jun 4, 2013 05:38 AM
war eagle
Jun 13, 2010 10:47 AM
D Appeldorn
Dec 21, 2009 02:12 AM
