Gasoline with Ethanol question
Old Dec 17, 2020 | 04:08 PM
  #81
eshawl's Avatar
The only time I saw valve recession is with high load engines, a lot of racing or heavy towing. As far as pushing hardened seats, can't explain that.
I have heard the same things you. are saying about high loads, racing and towing. The only other thing that was mentioned in addition to those you said is highway speeds as well. I t wasn't until the other day someone actually said what highway speeds was and it was speeds in excess of 60 mph. All of my speeds are between 55 and 80 mph for an hour straight. That is why I thought that the fuel mixing would be a good idea.
Old Dec 18, 2020 | 05:02 AM
  #82
I didn't even know leaded gasoline was still available. I imagine using it is sort of like using waste motor oil or ATF as fuel for an old diesel. It works but the environmental impact and cost are prohibitive.
Old Dec 18, 2020 | 05:14 AM
  #83
eshawl's Avatar
I believe almost all or most of the manufactures that produce racing fuels like "VP" still produce a leaded fuel option not to mention the aviation industry still uses leaded fuels for all non jet applications. The limited use of the product probably won't produce much of an environmental impact. In comparison to how many of these older cars are still out there driving in comparison to newer cars, it appears to be a non factor. Example of this is these older cars are grandfather into still being able to be licensed because back in the day catalytic converters weren't even invented for cars yet.
Old Dec 18, 2020 | 03:48 PM
  #84
FStanley's Avatar
some race gas still has a bit of lead..
.https://vpracingfuels.com/product/vp...-leaded/?c=217
Old Dec 20, 2020 | 07:05 PM
  #85
2Olds4U's Avatar
Majored in rear tire demo
Most Sunoco stations carry race fuel. Pricey though. This was $85.00 for 5 gallons.
A gallon added to a tank of 93 will probably take care of any issues. Ethanol damages old rubber fuel lines and seals very quickly. They have to be replaced with newer fuel injected rubber lines. This will help keep the ethanol from solidifying in dormant engines.
Old Dec 23, 2020 | 04:54 PM
  #86
Airbusflyboy's Avatar
Ethanol Fuel remedy
Get yourself a 5 gallon can , go to your local airport, find a tail number on a airplane and go to the front desk , tell them you want 5 gallons of AVFUEL 100 LOW LEAD for your airplane project, when they ask for the N number or Tail Number, same thing, give them the number ............. You will pay about $5 a gallon for this fuel but it is really super refined and in your car gas tank it will keep whatever junk you have in there for fuel from going bad for a while.
Don't buy into using RED STABIL fuel additive, it contains alcohol !!! Instead use the StarBrite brand fuel stabilizer , its in a clear bottle and looks a blue green color, much better for your fuel storage needs .........................
Old Dec 23, 2020 | 05:12 PM
  #87
eshawl's Avatar
This is basically what I do right now. I'm a pilot so I know the routine and is super easy at my local airport where its all self service. Thanks for the additional information. I know guys that run the a combination 75% 93 pump gas and 25% 100LL every other tank and then run a tank 93 pump gas and have not had any issues.
cdrod
Jul 4, 2016 07:48 PM
chip-powell
Jun 20, 2016 04:13 AM
Gary M
Mar 14, 2014 07:56 PM
2blu442
May 1, 2011 07:29 AM
jeffreyalman
Nov 5, 2009 05:52 AM
