Gas Tank sender hiting tube?
Old Jun 7, 2009 | 04:12 PM
dhoff's Avatar
Has anyone else experienced a problem with an aftermarket sending unit( parts place) maybe having the arm bent wrong and it hits the filler tube on a 72 cutlass or a aftermarket tank made wrong(specta canadian made)? It starts at empty fine, then as you fill it stops moving at almost 1/2 tank and stays there. It worked fine outside of the tank. I really can't wait to tear it out again. Dave
Old Jun 7, 2009 | 07:01 PM
gearhead1218's Avatar
Oh man, I'm keeping an eye on this thread.
I just installed a new Spectra tank this past Monday with a RobbMc sender. No problems thus far.
Old Jun 7, 2009 | 11:34 PM
Yellowstatue's Avatar
Smile PFD
The factory float bends 90 degrees to the drivers side, sounds like your float is catching on something? filter sock? sunken log?
Old Jun 8, 2009 | 03:49 AM
dhoff's Avatar
At a quick glance it looked to be the same as the origional one, but I'm thinking it must be bent slightly off or just enough longer that it catches. It still reads from 1/2 tank down,I'm waiting til I get a couple gas cans empty to drain the liquid gold into, then try again. Dave
joemo
Sep 21, 2022 04:47 AM
n_holman
Ninety-Eight
Nov 19, 2013 07:28 AM
1carsick
Oct 17, 2012 09:10 AM
Texas442
Jan 30, 2012 05:36 PM
bgoble
Apr 19, 2010 04:18 PM
