Fuel line bending tool
Old Apr 5, 2013 | 09:53 AM
pcard's Avatar
70 Cutlass SX
The dimensions on my fuel line are such that if I want to disconnect the line from the carb I have to take the carb off, otherwise the line butts up against the thermostat housing.
I just need about 1/2 inch so I am going to reshape the line, but wondered which was the best tool to use.
Anyone have a favourite.
Thanks, Peter
Old Apr 5, 2013 | 10:08 AM
allyolds68's Avatar
Thanks, Peter
Mine is similar to the one in this pic. I used it to fabricate my solid line from the fuel pump to the carb. I also used it for all my brake lines
Old Apr 5, 2013 | 12:43 PM
m371961's Avatar
That one works well, but if the flare is there and the bend needs to be close to the flare it may not be the best choice.
Here's oneAnd another
I used these 2 when doing all my brake lines.
Never used the plier type below
Del70
Dec 7, 2025 02:13 AM
70 ctls
Mar 17, 2015 09:18 AM
stlbluesbrother
Mar 21, 2011 03:24 PM
davepnola
Dec 2, 2010 09:00 PM
68conv455
May 20, 2008 02:03 PM
