Front Parking light bulb replacement
Old October 21st, 2014, 08:56 AM
gbbarr209's Avatar
1968 Olds Cutlass S model. Front Parking light bulb replacement. I have removed the two screws and chrome bezel. Before I attempt to pry this out is this the correct way to change the bulb? lens assy does not want to pull out with bezel off.
gbbarr209 is offline
Old October 21st, 2014, 09:43 AM
Octania's Avatar
yes, it is the right method
typically the gasket has become stuck to the lens.
pry gently and carefully.
I use the screw holes if possible
give it time- apply force and wait
if any section begins to move and come free, concentrate on that area.
you may break the lens anyhow. Can you get a new one ?
wire brush clean out the socket - plumbing wire brush may work.
put silicone grease on the base of the bulb to ward off oxidation.
finally, put silicone grease where the gasket contacts the lens, to ease future work, and ward off water entry, and put some on the screws as well, to ward off oxidation there.
Octania is offline
Old October 21st, 2014, 11:36 AM
Actually, there is a tool made specifically for this, available in auto parts stores under KD or Lisle brands, I think:
joe_padavano is offline
Old October 21st, 2014, 04:21 PM
gbbarr209's Avatar
Old October 22nd, 2014, 07:35 AM
gbbarr209's Avatar
Thank you. It worked great. removed and replaced bulb. after further inspection I realized the concern is the bulb works when turn signal is activated, however not when the lights are on.
Old October 22nd, 2014, 09:32 AM
Octania's Avatar
bad ground or faulty turn signal switch comes to mind. Does the TS Sw feel odd as you actuate it, like it may be broken inside? ALL the flasher and signal wiring runs thru that switch.
Octania is offline
Old October 23rd, 2014, 08:08 AM
That's a bad ground at the socket. The 1157 bulb has two separate filaments joined at the ground. When the ground is bad, the turn signal filament will ground through the parking light circuit, so long as the lights are off. When the lights are on, there's +12V on the parking light circuit and thus the turn signal doesn't have a ground path. Fix the bad ground.
Old October 24th, 2014, 03:23 AM
Yellowstatue's Avatar
Also, the '68 park light has a separate ground wire that is attached to the rad cradle in front of the battery. There are two or three wires grounded at that point, headlight etc.
Yellowstatue is offline
Old October 25th, 2014, 04:18 PM
Octania's Avatar
Here is what I meant for grease
for those who assert that DIELECTRIC grease is not for electrical connections, please not the wording pointed out.
[IMG][/IMG]
Octania is offline
pbarney
July 4th, 2018 02:57 PM
kansjfr
December 7th, 2014 05:10 PM
jamac
November 24th, 2014 05:33 PM
kansjfr
November 22nd, 2014 07:10 AM
75hurstoldsW-30
August 21st, 2014 01:24 PM
Quick Reply: Front Parking light bulb replacement
