Fresh built 350 rocket runs hot at high RPM
Could use some help please we have a fresh build 350 rocket aluminum heads comp cam flat tappet assembled and machine by motor builder in the area I live in the problem I’m having is I can drive around town all day around one 8190 temp wise I get on the interstate and start cruising after about 3 to 5 miles car starts creeping up 200 to 210 to 230 I let off the gas and cruise temp comes back down things I have tried and rulled out head gaskets are good, radiator hoses are not collapsing, brand new champion radiator with 2-14 inch electric fans,valve lash set correctly,no cracks in heads,water pump flowing correct,180 thermostat also tried 160,with all that being said it does not overflow in tank so not boiling over also got 2 different temp gauges just to rule out a bad one compression test leak down test down and check out any ideas would be helpful thanks again
I agree that it could be an air flow issue at speed.
One thing you didn't mention is the engine RPM when this happens.
During the 100+ summer temps, my car will run at 190 until I take it to 70 MPH+ highway speeds and over 3200 RPM, then the temp will start climbing. Backing down to under 3000 RPM and the temp drops back to 190. My cooling system just can't dissipate the heat generated by the engine turning 3000+ RPM with 100+ ambient temps.
Make sure all the shrouding and seals around the radiator are in place, especially the “chin spoiler” below the radiator. The little spoiler creates a low pressure area which encourages air thru the radiator.
All the baffles and seals are important, any air that goes around the radiator is air that isn’t absorbing heat.
Is the vacuum advance working? How is the tune? Lean mixture or retarded timing creates heat.
Matt asked about uum (aka vacuum) advance.
It's important for cool running of a street-driven car.
Check timing at idle and 2000 rpm with vacuum advance connected to manifold vacuum and check again with connection to ported vacuum. Let us know.
I will second that. Did an engine in a mid 80's Firebird and had the same exact problem. Turned out the spoiler was missing. Put one on and problem solved.
I REALLY need to get a new phone case. This one is really scratch up. Despite all the spelling and grammar errors, I’m actually a pretty good speller.
I’ll never understand how I fail to see the errors as I’m typing them, but when I read what I typed the next day they are so obvious Stevie Wonder could probably catch them.
Having said that, thank you for point out my spelling error. I corrected it, I think we can all agree the world is now a better place. 😁
The crazy thing is I never get coolent in the overflow tank I have tried two different gauges I also used a heat gun and the upper hose reads 193 and lower 180 checked timing with advanced hooked up and it will hit 53” timing at 3500 rpm
