fel-pro 1356 intake gasket or valley pan
when i install my aftermarket intake on the 1975 olds 455 should i go with something like the fel-pro 1356 4-piece gasket set or the original vally pan gasket?
OR
OR
Here's the difference, on the 4 peice you do not have the exhaust crossover port, which by the way most hi perf manifolds have that blocked off, on the valley pan you do. I you are using your stock manifold I would go with the valley pan. If you would like to use the 4 peice, simply make the opening or block the port.
70Cutlass_408
August 17th, 2011 01:08 PM
