fel-pro 1356 intake gasket or valley pan
Old May 22, 2012 | 08:31 PM
getitmann's Avatar
Delta 88 Rider
when i install my aftermarket intake on the 1975 olds 455 should i go with something like the fel-pro 1356 4-piece gasket set or the original vally pan gasket?
OR
Old May 23, 2012 | 06:22 AM
Never had a problem with the stock style metal gasket in nearly four decades of Oldsmobile ownership.
Old May 23, 2012 | 06:54 AM
Here's the difference, on the 4 peice you do not have the exhaust crossover port, which by the way most hi perf manifolds have that blocked off, on the valley pan you do. I you are using your stock manifold I would go with the valley pan. If you would like to use the 4 peice, simply make the opening or block the port.
Old May 23, 2012 | 07:27 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The valley pan is easier to install.
Old May 23, 2012 | 05:50 PM
getitmann's Avatar
Delta 88 Rider
Thanks, I do have the exhaust ports open on my intake so i think i will go with the valley pan. Gasket sealer on the water and exhaust ports only right?
Old May 25, 2012 | 08:40 PM
getitmann's Avatar
Delta 88 Rider
Good looking out classic olds crew, the info really helped, I went with the valley pan gasket and had no problem at all.
joepenoso
Feb 1, 2013 05:49 AM
70Cutlass_408
Aug 17, 2011 12:08 PM
defiant1
Mar 14, 2011 04:26 PM
Wasted
May 1, 2010 07:00 PM
Flye
May 12, 2009 05:30 PM
