E-Brake Cable Installation with Brakes in Place?
Old Jun 13, 2021 | 10:32 AM
WTHIRTY1's Avatar
Escape From The Ordinary
Is it possible to install the e-brake cables with the rear drum springs already in place? I just spent an hour trying to get it, and I cannot get the spring pulled back far enough on the cable to slot it in to the j-hook...assuming that's how it goes. Any tips for how to install these?
Old Jun 13, 2021 | 11:18 AM
mrolds69's Avatar
The rear cables are in, the front cable is in, you're struggling with the long intermediate cable that goes in the equalizer and the 3 hooks?
Old Jun 13, 2021 | 11:29 AM
mrolds69's Avatar
Jimmy if what I said is what you're dealing with, and assuming all the parts are right...connect the intermediate cable at the rear connectors first. Then hook it in the big hook. Pull it over to the equalizer and get that on with at least one nut. Then do the 2 small hooks. Finally, tighten the equalizer "al dente". It can be hard to install alone.
Old Jun 13, 2021 | 11:45 AM
Originally Posted by mrolds69
...tighten the equalizer "al dente".
Like a spaghetti noodle?
Old Jun 13, 2021 | 12:04 PM
mrolds69's Avatar
That's right, I'm hungry!
Old Jun 13, 2021 | 12:36 PM
I'm not sure I'm following here. Are you trying to get the intermediate cable into the hooks on the underside of the floorpan, or are you trying to get the rear cables hooked into the actuator arms under the rear brake shoes?
Assuming the latter, undo the retraction spring and retainer spring on the rearmost pad. That takes less time than writing this post. Done.
Old Jun 13, 2021 | 01:17 PM
I'm not completely following what the issue is. Is this what you're attempting to negotiate?
Old Jun 13, 2021 | 05:41 PM
WTHIRTY1's Avatar
https://youtu.be/p3nJztnLREE
Yes, but that’s straight forward with all the brake parts removed for easy access.
Old Jun 13, 2021 | 06:10 PM
OK I wasn't certain if that was what you were referring to. You'll need to remove the retraction spring/retainer as Joe indicated - not really all that difficult.
Old Jun 14, 2021 | 05:07 AM
See Post #6. You only have to remove the rearmost shoe. All kidding aside, we've spent more time talking about this than it takes to do it.
Old Jun 14, 2021 | 01:52 PM
Tighten it to "chewy"?
Dave26
Non-Olds Engines
Oct 20, 2019 02:45 PM
jRoofgunner
Nov 20, 2017 07:24 AM
VI Cutty
May 14, 2017 09:25 PM
oddball
Brakes/Hydraulic Systems
Dec 21, 2016 07:29 AM
70redvert
May 9, 2008 09:38 AM
