Double Hump Crossover
Old July 14th, 2011, 07:22 PM
74 Omega's Avatar
I was wondering if anyone knows the answer to my question of was a double hump crossover offered in my 74 Omega? It was in there when I bough the car. seemed to be original but the transmission is sitting a little high on the back side, (not as level as I think it should be). I don't think duel exhaust was offered so I see no reason a double hump would be there from the factory.
Thanks for any info.
BTW is a 350/350
74 Omega is offline
Old July 14th, 2011, 08:05 PM
Oldsdruid
rocketraider's Avatar
Since an Omega is basically a Nova in drag, and 68-74 Novas DID have dual exhaust option, stands to reason the same crossmember is used in Nova, Apollo, Ventura and Omega.
I can't visualize GM having separate part numbers for single/dual exhaust applications on the X car when the A-B-C-E cars all used the same crossmember for both dual and single exhaust cars thru 1974.
rocketraider is offline
Old July 15th, 2011, 02:30 AM
74 Omega's Avatar
Thank you...
74 Omega is offline
Old July 15th, 2011, 05:28 AM
Lt. Buzzkill (ret.)
copper128's Avatar
Dave, I'm pretty sure all the X-body cars used the same double-hump trans crossmember right through 1979. The subframe did get some changes in 75 to accomodate the new front-steer arrangement, but it was mostly unchanged from it's original version dating back to the 67 Camaro/Firebird and adapted to the Nova in 68.
copper128 is offline
marxjunk
February 20th, 2015 07:25 AM
Gustav455
17
February 18th, 2012 05:34 PM
Gearhead442
January 7th, 2010 07:23 AM
74omega
November 30th, 2008 04:09 PM
shaks 442 clone
February 17th, 2008 04:55 AM
Quick Reply: Double Hump Crossover
