Door Latch 67 Cutlass
Old May 12, 2020 | 08:43 AM
Rocket Fire V8's Avatar
I’m doing a power window conversion and while everything is out, hey, how about the door latches too? The wire or spring that wraps around the top of the latch...should it be wound tight? Mine is in the attached pic. Notice how that wire looks kinda unraveled? Normal?
Old May 12, 2020 | 11:17 AM
If it was working before, why do you think there's something wrong with it? No, it isn't supposed to be wound tightly. If it were, it wouldn't have been possible to fit over the head on that post. Note that the ID of the spring is sized to allow it to fit easily over the head. Once in place, the spring force holds it to the side like that, and it then can't pop off past the head.
Old May 12, 2020 | 11:39 AM
Joe is always there when you need him. I guess I was trying to account for that little bit of play or slack in the door button. Drivers side has it, passenger doesn’t.
Old May 12, 2020 | 12:25 PM
That's called manufacturing tolerance. The location of that paddle that the push button presses against is governed by a hard stop in the mechanism, not the spring. Minor variations in the shape of the outer door panel, the length of the stud on the back of the pushbutton, and the position of the latch mechanism in the door all contribute to slop (or lack thereof).
Old May 12, 2020 | 12:38 PM
Bw1955's Avatar
Door latch
Do they sell those springs, I have a broken one on my drivers door?
Old May 12, 2020 | 12:42 PM
You're in luck. Apparently they're the same as the ones on first gen Camaros, so EVERYONE sells them...
https://fbodywarehouse.com/store/196...left-hand.html
Old May 12, 2020 | 01:01 PM
Bw1955's Avatar
Door latch spring
Thanks Joe,
ive been all over the internet today looking for one. Really didn’t want to spend the money on a new latch. Just ordered it. Appreciate the knowledge you share with us.
Old May 12, 2020 | 01:47 PM
Thanks Joe,
You did note they come in RH and LH, right?
Old May 12, 2020 | 07:36 PM
Appreciate the info. Also good to know that one can replace just the springs if desired.
Old May 12, 2020 | 07:41 PM
Bw1955's Avatar
Door latch
Yes I saw the left and right, thanks
csouth
May 14, 2018 12:32 PM
Oldsnut73
Nov 12, 2017 12:39 PM
donfitzgerald
Aug 21, 2014 07:25 AM
Sampson
Apr 25, 2014 04:45 PM
1967cutty
Nov 6, 2011 08:49 AM
