Dash Vent Duct
Old Nov 11, 2019 | 07:52 AM
Phoenix8990's Avatar
Dash Vent Duct
I have a 69 Cutlass w/ac, the rectangular flex duct to the side dash vents is in rough shape. I don't see it available anywhere. I'm confident someone has come up with a replacement. Has anyone tried squaring up 3 1/2" diameter flex to see if that works or have another suggestion?
thanks,
Steve
Old Nov 11, 2019 | 01:57 PM
bry593's Avatar
1968 442 Convertible
Vintage air makes adapters to fit the 2.13 x 2.63 rectangle found on the plenum and outer louvers. It is p/n 496083 and you should request (2) "S" clips per adapter. For the obround driver side of the plenum, there is no good solution other than getting creative.
Old Nov 14, 2019 | 02:59 AM
rob1960's Avatar
I saw this on Summit's website. I was thinking about ordering one for my '68. It's an air cleaner intake duct that fits many jeep models, it's plastic not cloth if that matters to you. I don't know why the whole link didn't post but it's made by Crown automotive & the size is approx 3 1/2" x 2"
Old Nov 14, 2019 | 08:04 AM
I wrapped the disintegrating ducts with tape. I used black electrical tape but it seems as if there is some type of tape made especially for this, but I can't remember what it's called...
Old Nov 14, 2019 | 01:42 PM
akspeedy's Avatar
Duct tape LOL!!!
Old Nov 14, 2019 | 03:19 PM
Yellowstatue's Avatar
^^^ x2 :d
Old Nov 15, 2019 | 03:24 PM
oldsonharmont's Avatar
I'd suggest looking on Amazon for 'gaffers' tape instead of 'duct' tape. Gaffers tape is usually black and comes in the same size rolls. It's cloth based, easy to work with, and will adhere to your existing cloth and wire ducts much better that Duct tape which is shiny, slick and does not adhere well to those automotive style A/C ducts.
Old Nov 16, 2019 | 01:14 PM
cdrod's Avatar
Rodney
Phoenix:
The driver side duct is 2-1/2"x 3" square which equates to a standard size 3-1/2" round duct. The passenger side duct is 1-3/4"x 4" which equates to 3.66" round duct (not a standard size). If your ducts only have a few tears in them, they can be fixed with gaffers tape as was previously suggested. My passenger side duct was torn in the middle section. I masked off the damaged area and sprayed with 3M trim adhesive, then wrapped the tear with black gaffers tape. I then sprayed the whole duct with FlexSeal (the stuff you see on TV) which sealed up the pin holes as well as the gaffers tape and the duct is still flexible. Here's a pic:
Old Nov 16, 2019 | 05:49 PM
Guy Fillinger's Avatar
Duct Work
Check with Rocket Scientist who is on this forum. He has an absolute ton of parts, he may have what you are looking for. Guy
Old Nov 17, 2019 | 08:45 AM
bry593's Avatar
Old Nov 17, 2019 | 11:21 AM
I was thinking that if I could find 3 1/2" flex I could square it up and it would be a close fit but that square to round adapter would probably work nicely. Where is it from? Thank you all for your suggestions. I'll also reach out to Rocketman, oops, scientist.
thanks,
Steve
Old Nov 17, 2019 | 03:50 PM
bry593's Avatar
thanks,
Steve
see post #2 for vintage air p/n.
Old Nov 18, 2019 | 07:59 AM
Nice restoration on the duct. I have looked at Vintageair.com and the # doesn't come up. I don't doubt they have it but any chance you have a direct link?
thanks,
Steve
Old Nov 18, 2019 | 12:45 PM
oddball's Avatar
Originally Posted by cdrod
Phoenix:
+1. I used 3M's mylar tape for actual home ductwork - found in any local home improvement store.
Old Nov 18, 2019 | 01:02 PM
bry593's Avatar
thanks,
Steve
Did you try using a telephone? 1-800-862-6658
By the way, I recommend sealing the adapters to the original components using HVAC foil tape: https://www.lowes.com/pl/HVAC-foil-t...pes/3381603586.
geoff442
Oct 25, 2019 03:50 AM
Microreedy
Oct 12, 2015 06:25 AM
jason
Jul 23, 2013 10:55 AM
Gary's 2 442-S
Nov 4, 2011 03:23 PM
jo75olds
Apr 26, 2011 07:19 AM
