cutlass window stops
I know where the red guide on the right goes. I can't remember where to attach the left one with the rubber stop. I know it goes on the door windows. Any help is appreciated.
That up-stop should go on the regulator towards the front of the car. It hits the top of the inner door shell when window is all the way up. The back one (not pictured here) is pointed and goes through a hole in the door shell when up.
That worn guide on the right can be fixed with 2" wide self-stick velcro. There should be another smaller one in the door that can use velcro also. Replacsing that can help prevent scratching of the glass when too much of the material gets worn away.
Some destructions here and in next two slides...
https://www.flickr.com/photos/robsal...57602930020786
Thanks! I already pulled the old cloth off the inner & outer guides & figured on putting the fuzzy part of the velcro on them. Will the self sticking kind stay stuck? What time & temp did you cook them at?
MudEye
January 30th, 2012 07:36 PM
Oldsguy
November 17th, 2008 07:01 AM
