Cruise control speed regulator
The Dana Corp/Perfect Circle speed control regulator on my 77 Cutlass is 554888. Does anyone have a cross reference as to what other regulators will work in place of the 554888?
I have one that came out of a 76 Cutlass Salon. Same as for 77 I believe. I wire wheeled it when it came home. Didn't have the Perfect Circle emblem on it though. Here's some pics. Not tested. Sorry the pics are a bit blurry. I can take more if you're interested.
![](/forums/attachments/general-questions/112804d1427505603-cruise-control-speed-regulator-img_1098.jpg)
![](/forums/attachments/general-questions/112805d1427505603-cruise-control-speed-regulator-img_1099.jpg)
![](/forums/attachments/general-questions/112806d1427505603-cruise-control-speed-regulator-img_1100.jpg)
Thanks. I just replaced the 260 in my 77 Cutlass with a 350. The 260 did not have factory cruise, just an aftermarket unit. At this point I have all the parts needed to install factory cruise on the 350. I just don't know if the regulator is operable so I'm looking for regulator numbers that will interchange if mine doesn't work.
mruders
February 4th, 2014 08:15 AM
