Cowl Tag decipher - vinyl top or not?
Old Sep 12, 2009 | 12:48 PM
oldzy's Avatar
I am fairly certain my 72 Cutlass Supreme had a vinyl top originally, but if I am reading the below right, 14/14 means both the top and bottom were Silver Pewter Metallic. When I got the car it had what appeared to be an original vinyl top... perhaps not, but it looked weathered, had the 2 x CS emblems on either side, etc. There was no padding underneath though.
Is it possible the dealer installed the vinyl top?
Old Sep 12, 2009 | 01:53 PM
You are correct - 14 14 shows paint top and bottom. Dealer installation of vinyl tops was not uncommon then.
Old Sep 12, 2009 | 02:08 PM
oldzy's Avatar
Thx. So I am safe to do either way... however it did not come from the factory w/ vinyl so... guess I will have to think on it some more.
What I hate about the vinyl that is on it, is that quite a bit of the steel underneath is totally rotted, mainly on the sides where the CS emblems were.
Old Sep 12, 2009 | 06:11 PM
mugzilla's Avatar
is Fast Enough ...
Luckily my vinyl top was totally wasted with just a li'l surface rust and maybe 5 pin holes rusting through ...
I did not replace ...
tomg63
Tech Editor's Desk
Aug 27, 2014 01:29 PM
Blackpage
Nov 4, 2011 08:04 AM
Ddbord
May 18, 2010 07:59 PM
442C.D.
Sep 13, 2009 06:24 PM
jensenracing77
Jul 30, 2009 04:50 PM
